Traffic flow
I am having 2 routers connected with 2 switches as given in the attached diagram:
When data is going from network A to Network B it is going from
switch 1 --- R1 f 0/0---  R1 f 0/1 --- switch 2--- R2 f 0/1---- R2 f0/0 --- switch 1 --- Network B
We want to remove one router and we want the same flow from single router.
Can anyone suggest me what can we do on the router for the same data flow?
Hall of Fame Super Silver
Seems like a very artificial
Seems like a very artificial problem.
Is this a class assignment? If so, it wouldn't be fair to get your answer here.
Its not an artificial problem
Its not an artificial problem.
I have replaced both routers with a single router and i have enabled VRF on it. Now i m trying the same flow.
If you have any suggestion for me on this please tell me?
Mukesh Kumar
Network Engineer
Spooster IT Services
If network a and b are both
If network a and b are both on switch 1, what's the point of involving switch 2?
Simply either:
a. use two interfaces on the router (one on switch 1 interface associated with network a and one on switch 1 interface associated with network b) or else,
b. make the router to switch a interface a trunk on the switch side and use sub interfaces on the router to tag the traffic appropriately.
No VRFs required in either case
Thanks for the information
Thanks for the information Marvin.
Can we enable redistribution between static routes in different VRF's?
Mukesh Kumar
Network Engineer
59
