cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Recurrent temperature minor alarm in one fabric module - Nexus 7010
Hello:
I'd like to know what corrective actions should be taken when one (just one) module in a nexus 7000 suffers a recurrent temperature increasement that generates a minor alarm. The official documentation only suggests to check the show environment output, but it doen not says what to do after you have make sure that the module temperature is upper than the min threshold. It would be very helpful if Cisco'd include some actions to take, like checking the air filters, for example.
Can any one give any suggestions?
Thanks in advance.
2 RESPUESTAS
I am experiencing this at the moment. One fabric module xbar3 on one of an identical pair of nexus7010 is having this problem. I had the thought over the holiday about the filter on the front of the chassis. Came in this morning and gave the filter a good hoovering. Am keeping an eye on the situation, though so far the modules are cool to the touch whereas previously hot.
Jim Barrie
Gentlemen,
I think you better post this on this forum:
https://supportforums.cisco.com/community/netpro/data-center/server-network
This section is an Spanish forum, not that we can't help you here, just trying to point you to somewhere where you will get an answer in your language.
-Kenny
Caballero,
Creo que lo mejor que pueden hacer es preguntar en este otro foro:
Esta parte del foro es en Español, no que no les podamos ayudar, sino que los quiere enviar en la dirección correcta donde vayan a recibinr una respuesta en su idioma.
-Keny
539
Visitas
ÚTIL
Respuestas
CrearPor favor para crear contenido
