4310 - Programming the Remote to Switch to Cast
I have been trying to program a remote control to switch the DMP to Cast.
I've read this thread - which I think only applies to the 4400?
https://supportforums.cisco.com/thread/2040917
It did help some.
Also for anyone else reading this I've found you can point a 4310 DMP to this URL and it will open Cast
Remember the 4310 as of this time does not support HTML
Flash URL= https://DMM.IP.add.ress:8080/etv-flash-webapp/ETV.swf
I am able to use a HTTPS URL to switch the DMP to cast fine.
This is the URL in my case
https://192.168.119.154:7777/set_param?ciscocraft.fl_url=http%3A%2F%2F192.168.119.221%3A8080%2Fetv-flash-webapp%2FETV.swf&ciscocraft.fl_submit=1
This switches the DMP to cast in a few seconds in full screen
But the customer would like to use a button on the remote.
Following along with what I've seen for the 4400 I've tried this for my 4310
https://192.168.119.154:7777/set_param?irasrv.key_BLUE=ira%20add%201%20sh%201%20BLUE%20bg%20wget%20-q%20%22localhost%3A7777%2Fset_param%3Fciscocraft.fl_url%3Dhttp%3A%2F%2F192.168.119.221%3A8080%2Fetv-flash-webapp%2FETV.swf&ciscocraft.fl_submit%3D1%22
That equals this without the escaping
ira add 1 sh 1 BLUE bg wget -q "localhost:7777/set_param?ciscocraft.fl_url=https://192.168.119.221:8080/etv-flash-webapp/ETV.swf&ciscocraft.fl_submit=1"
Is this what it should be for a 4310 or should it have
ira add 1 ciscocraft BLUE  something else "localhost:7777/set_param?ciscocraft.fl_url=https://192.168.119.221:8080/etv-flash-webapp/ETV.swf&ciscocraft.fl_submit=1"
Is there any other info on the command syntax to use for programming the remote?
I've got the DMP4310_MIB.PDF but it really doesn't go into enough details.
Marc
Everyone's tags (3)
493
