Community Member
A problem with Static/RSS ticker
Hello everyone!
I have a test lab set up (DMM 5.1 and DMP-4305G, license is OK).
I made a few presentations with Cisco Digital Media Designer that included video, text ticker and RSS ticker.
Video works fine.
Static text ticker almost works perfect, only i can't change the effect of text (it's alwys fadeing even if i change it to left/fight scroll).
RSS feeds are visible in Cisco Digital Media Designer and seems to work, but when i play it on DMP, the box with rss feed is blank.
Please, i need some advice, i tried everything i could think of...
Best Regards,
Ales
Everyone's tags (4)
Community Member
Re: A problem with Static/RSS ticker
Hi Ales
Can you upload the RSS feed that you are using?
I had problems with RSS feeds and is not shown in the display, but it solved by removing a few lines of code in the XML file.
The DMP 4305G only support "fade in fade out" effect, this is a limitation.
The DMP 4400 support "fade in fade out" and "Scrolling" effect.
Community Member
Hi Ales
Community Member
Hi Aurelio,
Thank you for your post!
This is the rss link i am using:
http://www.rtvslo.si/slovenija/rss
As i said link appears to work in  Digital Media Designer.
When scheduling the presentation to DMP i have no result.
I tried different links. This for instance link works perfect-> http://newsrss.bbc.co.uk/rss/newsonline_world_edition/europe/rss.xml
i also copied the source code of bbcRSS and modified it (it is attached to this post) and put it on my web server, checked it with explorer - it works;
on Digital Media Designer the link is not reachable, please advise.
What could be the issue? Character coding maybe?
( i also noticed by using static ticker that DMP-4305 can't show slovenian special characters => š č ć ž )
Does DMP-4305 / Digital Media Designer support different character coding?
Thanks again for you help,
Cheers!
Ales
1173
