AppSpace Rs232
AppSpace 5.0.3
DMP4310 - NEC X55 talking over RS232
AppSpace has come out with their ADM - Advanced Device Manager.  I am using this to communicate to my
DMP4310G - I am trying to schedule a screen to - 8am turn on and a 5pm turn off.
I schedule it, wont work..
but
I can make it work if I click on immediate
- instead of schedule - then it works.
1 ACCEPTED SOLUTION
Hi Grant,Instead of using ADM
Hi Grant,
Instead of using ADM try using player properties for this...
Below are the player properties to use. The NEC codes I have used in the example will need to be changed with the HEX codes you have.
NEC On-off codes
Command                         Value
Display.Screen Burn Mode          1
Display.Screen Burn OFF Command          01304130413043024332303344363030303403760D
Display.Screen Burn ON Command          01304130413043024332303344363030303103730D
Display.Screen Burn Time          14:29, 14:32
P.S.
Hi Grant,
NEC On-off codes
Command                         Value
P.S.
Hi Grant, Can you please let
Hi Grant,
Can you please let me know the procedure on how you deployed. It will be of great help.
I am trying on both Cisco DMP 4310 and Edge 340, but getting the attached response
Kindly help.
Shabeer
490
