02-03-2014 12:55 PM - edited 03-13-2019 08:29 PM
I installed version 5.0.3 AppSpace, once installed and registered the Licenses, Entrance via web admin page, but when I deploy the administration menu, I loaded all options under "library" and "user". Validate java versions and recommended by AppSpace browser, but I still can not open these options.
Solved! Go to Solution.
02-08-2014 05:06 AM
Hi Arlex
I hope you are so fine.
Can you try to open the Appspae using google chrome ?. I hope also that you server find the below :-
On-Premise Specifications
Item Minimum Specification Recommended Specification
Operating System Windows Server 2008 R2 Standard Edition 32-bit Windows Server 2008 R2 Standard Edition 64-bit
CPU 2 x Intel Xeon E5520 @ 2.26 GHz 2 x Intel Xeon X5560 @ 2.8GHz
Memory 8GB RAM @ 1333 MHz 16 GB RAM @ 1333MHz
HDD 3 x 250GB SATA, 7.2K RPM, RAID-5 4 x 500GB SATA, 7.2K RPM, RAID-10
Network Dual 10/100/1000 NIC Dual 10/100/1000 NIC
VMware Specifications
Operating System Windows Server 2008 R2 Standard Edition 64-bit
CPU Intel Xeon @ 2.5GHz
Memory 8GB RAM
HDD 500GB
Please rate all useful information
02-08-2014 05:06 AM
Hi Arlex
Memory 8GB RAM
HDD 500GB
02-08-2014 05:07 AM
02-10-2014 01:10 PM
You are right, I had forgetted install the service pack 1 in the server.
