Appspace v5.0.3
Arlex Ibanez
I installed version 5.0.3 AppSpace, once installed and registered the Licenses, Entrance via web admin page, but when I deploy the administration menu, I loaded all options under "library" and "user". Validate java versions and recommended by AppSpace browser, but I still can not open these options.
Can you help?
Thank you.
islam.kamal
Level 10
Level 10
Hi Arlex
I hope you are so fine.
Can you try to open the Appspae using google chrome ?. I hope also that you server find the below :-
On-Premise Specifications
Item Minimum Specification Recommended Specification
Operating System     Windows Server 2008 R2 Standard Edition 32-bit     Windows Server 2008 R2 Standard Edition 64-bit
CPU     2 x Intel Xeon E5520 @ 2.26 GHz     2 x Intel Xeon X5560 @ 2.8GHz
Memory     8GB RAM @ 1333 MHz     16 GB RAM @ 1333MHz
HDD     3 x 250GB SATA, 7.2K RPM, RAID-5     4 x 500GB SATA, 7.2K RPM, RAID-10
Network     Dual 10/100/1000 NIC     Dual 10/100/1000 NIC
VMware Specifications
Operating System     Windows Server 2008 R2 Standard Edition 64-bit
CPU     Intel Xeon @ 2.5GHz
Memory     8GB RAM
HDD     500GB
Please rate all useful information
islam.kamal
Level 10
Level 10
Hi Arlex
Memory     8GB RAM
HDD     500GB
Hi Alrex
Can you also find the attached file ?. I follow all steps and my server is woring very well.
islam
You are right, I had forgetted install the service pack 1 in the server.
