Appspace v5.0.3
I installed version 5.0.3 AppSpace, once installed and registered the Licenses, Entrance via web admin page, but when I deploy the administration menu, I loaded all options under "library" and "user". Validate java versions and recommended by AppSpace browser, but I still can not open these options.
Can you help?
Thank you.
1 ACCEPTED SOLUTION
Appspace v5.0.3
Hi Arlex
I hope you are so fine.
Can you try to open the Appspae using google chrome ?. I hope also that you server find the below :-
On-Premise Specifications
Item Minimum Specification Recommended Specification
Operating System     Windows Server 2008 R2 Standard Edition 32-bit     Windows Server 2008 R2 Standard Edition 64-bit
CPU     2 x Intel Xeon E5520 @ 2.26 GHz     2 x Intel Xeon X5560 @ 2.8GHz
Memory     8GB RAM @ 1333 MHz     16 GB RAM @ 1333MHz
HDD     3 x 250GB SATA, 7.2K RPM, RAID-5     4 x 500GB SATA, 7.2K RPM, RAID-10
Network     Dual 10/100/1000 NIC     Dual 10/100/1000 NIC
VMware Specifications
Operating System     Windows Server 2008 R2 Standard Edition 64-bit
CPU     Intel Xeon @ 2.5GHz
Memory     8GB RAM
HDD     500GB
Please rate all useful information
Appspace v5.0.3
Hi Arlex
Memory     8GB RAM
HDD     500GB
Re: Appspace v5.0.3
Hi Alrex
Can you also find the attached file ?. I follow all steps and my server is woring very well.
islam
Re: Appspace v5.0.3
You are right, I had forgetted install the service pack 1 in the server.
598
