Community Member
Audio only podcasts
Does anyone capture audio only files and make them available as podcasts using Show and Share?
If so, can you please tell me what products you use to transcode the audio file into a file that can be input into Show and Share?
I understand video files can be recorded directly in Show and Share (video and audio) and also that various video formats (captured on hand held devices)  can be transcoded using MXE 3500 so the output file can be used with Show and Share.
My question pertains purely to captured audio files (using desktop and microphone only) and how they can be made available for use with Show and Share.
Many thanks
1 ACCEPTED SOLUTION
Re: Audio only podcasts
Linda,
The Show and Share is typically used for video content sharing.
The supported formats are Windows Media, H264, and Flash.
That said you can always take an existing audio file and
try to transcode  into an audio only video file.
I tested the following scenario and it does work on the
show and share.
I took and audio only .mp3 file and opened it using Quicktime.
I then exported the audio to a video using H264 format.
I then verified the Media codecs in the new transcoded file.
I uploaded to Show and Share and it plays the Audio\empty video
file fine.
I hope this helps!
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Linda,
show and share.
file fine.
I hope this helps!
Thank You!
T.
Community Member
Thank you Tomas.
471
