Cisco 892
Does anyone knows that cisco 892 integrated service router supports DSP ?
Aateek singh
Network Engineer
Spooster IT Services
Hall of Fame Super Gold
800-series routers do NOT
800-series routers do NOT support DSP.  There's no room and CPU power.
Thank you Leo.It means router
Thank you Leo.It means router 892 doen't support Voip?
I wanted to create a ccna voice lab. Any advice would be great as regarding router 892 supporting Voip with CME
I have found 1 doc it states 892 router supports CME ,but as you mentioned that 892 doesn't support DSP , THEN how it will support CME and Voip
http://ptgmedia.pearsoncmg.com/images/9781587132995/samplepages/1587132990.pdf
Aateek Singh
Network engineer
You can install CME on 800
You can install CME on 800 routers but you need a minimum of 1 Gb DRAM and a CME license.
Cisco Unified Communications Manager Express System Administrator Guide
Release Notes for Cisco Unified Communications Manager Express
Thank you Leobut i'm not able
Thank you Leo
but i'm not able to undersatnd that if router 892 doesn't support DSP
and if DRAM of 1 Gb and a CME license will help to install CME
so in totality will it support VOIP without DSP?
Aateek Singh
Network Engineer
73
