Cisco DME 1100 not booting
Hi There,
We have a Cisco DME 1100 that is not booting up.
It started by freezing once or twice at which point I rebooted it whch got it working but now the unit does not boot up at all. If I apply power and toggle the state the LCD screen comes on with info stating 'booting...' but just goes no where. If I connect a monitor to it, it does not display anything as well as it constantly makes a beeping tone...
Is there anything I can try to reset the unit or what this could mean?
The last time I got any screen image out of the unit it was displaying the following information:
"Windows could not start because the following file is missing or corrupt:
C:\Windows\System32\Config\System" - This can only be bad...
Thank you,
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Cisco DME 1100 not booting
Ok so after some investigation we found that the DME runs Windows Embedded as its OS.
We managed to get a copy of the OS and performed a windows repair using an external USB DVD drive.
The DME is now back up and running.
Hi Michael,
If the unit is not showing anything at all when connecting screen/keyboards, there won't be much more investigation possible. Likely the HW has gone bad and you will have to replace it.
Marco
485
