Cisco DMM scheduling
Dear Experts,
I am trying to a scheduled broastcast of video from the DMM. The video is 3mins and 44secs long.
We planned to start the video at 8am and we should stop the video at 8:03:44 am. Since the DMM doesn’t have an option on Start/Stop in seconds, we could only stop the broadcasting at 8:04am. However, there are 16 seconds more, so the video will loop again and will shows the first 16seconds of the video.
Is there any workaround for this?
Thanks!
Hello there,
if i recall correct, within the playlist you can edit the video file and actually define the duratin. there is a small arrow that by clicking on it you can select duratin "end of file"
have you tried this?
Thanks for replying but couldnt find the small arrow.
What version are you running?
ours is 5.3
also, you editi this in the playlist not within the video asset properties.normally, for videos you edfine the duration as 00:00:00 and then finally you set the desired planned duration (as shown below)
393
