Design Cisco Digital Media Signage
Dear All,
I am trying to design a cisco digital media signage for HQ and 5o remote locations,
I have found in order to build the design the network to install a cisco digital media manager at HQ and digital media player at remote locations.
During my search I have found Cisco Digital Media Suite - Cisco Digital Media Manager v.5.2.3 for DMM and Cisco Digital Media Player 4400  for DMP, but the issue  the Cisco Digital Media Suite - Cisco Digital Media Manager v.5.2.3 is end of sale
But I could not find a replacement for Cisco Digital Media Suite - Cisco Digital Media Manager v.5.2.3.
The question is that the right approach to design a  cisco digital media signage?
And what is the replacement for Cisco Digital Media Suite - Cisco Digital Media Manager v.5.2.3.?
Thanks for your support in advance
Abdallah
Everyone's tags (1)
Hall of Fame Super Gold
Cisco DMS has been replaced
Cisco DMS has been replaced with a third-party solution called AppSpace's Nexus-on-Demand which Cisco now re-sells.
Thanks Leo
Thanks Leo but I would like to what's the main components required to design network that can broadcast media( video , flash ppt.....) and addtinal features can be add to the main . Thanks Abdu
Hi Xavi As Leo mentioned ,
Hi Xavi
As Leo mentioned , you go to Appspace Solution which will help to display all the contents as you wish by an application design.Kindly find the below:-
1- You will need for H/W " Cisco UCS C22M3 , or any higher model".You can use only one appliance or you can use two appliances for HA.
2-Microsoft windows 2008 , or 2012.
3-My SQL.
4-Appspace S/W latest release 5.0.3.
5-Cisco DMP "Edge players 340" as example.
please rate all useful information
Hi To display your contents ,
To display your contents , you have to create application and this application will contains all " video  , slide show , flash , RSS , ppt , IPTV , ect....). Appspace is the best for digital signage .
Hi1- You can used Cisco DCM
1- You can used Cisco DCM 9900 to allow push multicast IPTV channels MPEG2 .
2-You should have multicast running on your network to allow IPTV running ok.
3-Using on-premise Appspace " you can push contents to display on screes ".
4-Appspace has IPTV application which is very perfect designed based on customer requirements .
5-You can did a special design for one of the application and go inside the application and create Layout and designed an area for IPTV.
please rate all useful infromation
HiIf you are looking for a
If you are looking for a BOQ , kindly find a sample as below:-
DMS-NOD-FL-50DMS Nexus on Demand Feature License for Up To 50 DMPs
DMMC210-NOD-K9DMS Nexus on Demand Digital Media Manager Server  HW
CON-ECDN-DMMC210NESS WITH 8X5XNBD DMS Nexus on Demand Digital Media Mgr
DMS-NOD-AS-K9DMS Nexus on Demand App Space Base SW
DMS-DMPNOD-FL-50DMS DMP NOD Feature License for Up To 50 DMPs
Please rate all useful information
Thanks Islam for your
Thanks Islam for your response
It's helpful to me
Hi XaviYou are very welcome
Hi Xavi
You are very welcome any time . If you need help  kindly ask only.
Thanks for rating and Good Luck
Thanks ISLAMThe thread is
Thanks ISLAM
The thread is useful to me.
one item is missing; is the TV channel integration, what i understood we need decoder to convert the RF signal into IP level then multicast it to the remotes.
what do suggest for the encoder and what is the module P/N needed in order to integrate it with Appspace?
Abdallah
HiFor IPTV ,there are many
For IPTV ,there are many vendors for IPTV. I recommended for you Cisco DCM 9900 , very good encoders very stable . Kindly find the below :
http://www.cisco.com/c/dam/en/us/products/collateral/video/transcoders/7017813.pdf
http://www.cisco.com/c/dam/en/us/td/docs/video/headend/DNCS/78-4003867-01_B.pdf
After you finish installation of Cisco DCM encoders ,or any other vendors . you should get a multicast IPs for TV channels .
On Appspace , you have two options:-
1- Appspace IPTV  application.
2-You can design an area on your application , and put a multicast IP for TV channels.
If you need any help , kindly share with me your information
Hi ISLAM, I have noticed most
Hi ISLAM,
I have noticed most of the items are End-of-sale End-of-life
do you a  the replacement for that
Abdallah
Hi abdallh I shared with you
Hi abdallh
I shared with you just an example for Nexus solution , yes it is old . Kindly share with me what is your requirements and i will do my best to help you. you have to get the below:-
1-No.of Players or numbers of screens .
2-how many wired players , and wireless ?.
3-If you will work for HA , you have to purchase two servers.
Hi Islam,actually, I've a
Hi Islam,
actually, I've a customer who is looking for a digital signage in the HQ (10 players) and according to the Cisco ordering guide, i found the following part numbers:
CS-E300-K9             (Cisco Edge 300 DMP)
L-DMS-AS-PRO      (Appspace Pro)
L-DMS-PRO-CAL-1       (QTY 10)
so my question is that is that the right design or I've to go with Cisco DMM 5.4 and 4310 DMP?
second is, to resell the appspace application, does it require any additional partnership specialization with Cisco?
thanks,
Hi 1- Edge players 340 ,
1- Edge players 340 , Excellent players which display contents very well and its processor very well.You do not have to go DMM solution , go direct to Appspace on primes , this a very wonderful solution for digital signage now days.
2-Yes , you have to be a ATP partner Authorized Technology Provider.
Hi All, I have come with
Hi All,
I have come with following network setup in order to meet the design
In the HQ the following items will be used:
Item
Descriptions
QTY
R-DMM-BASE-54-U-K9
Digital Media Mgr V5.3-V5.4 Perptl SW Lic. Update
R-DMP-4400-54-U-K9
DMP 4400 Firmware Version 5.4 Update
DMP-FL-50=
Device Management Feature License for up to 50 DMPs, Spare
For the remote sites I am planning to use the following items:
Item
Descriptions
QTY
DMP-4400G-54-K9
DMP 4400 4GB with Accessory Kit
50
R-DMM-BASE-54-U-K9
Cisco Digital Media Manager V5.3-V5.4 Perptl. SW Lic. Update
R-DMP-4400-54-U-K9
Cisco Digital Media Player 4400 Firmware Version 5.4 Update
LCD-110-PRO-52S
Cisco LCD 52" Display, 1080p Bezel S, With Remote Control
50
My question is there anything missing with setup in order to meet the system functionality?
2537
