DMM administrator role only retains superuser post restart
Hi All,
I'm currently running DMM version 5.1 and use LDAP authentication to access the DMM.  I currently have 3 users defined in the Admin role, myself and two others.
Whenever I perform a restart of the DMM (Using Administration interface, Services tab, then clicking on Options, Restart Server), all administrators from the Admin role disappear and none of the administrators can log on with their own credentials but rather have to use the 'superuser' account until I re-add all into the Admin role.
Does anyone have the same issue and how do you resolve it?
Thank you
Cheers
Linda
1 ACCEPTED SOLUTION
Re: DMM administrator role only retains superuser post restart
Linda,
My apologies.
This is a known issue:
CSCta11809 - DMM: User Role changes from ADMIN to READ ONLY (LDAP)
The issue has been fixed in DMS 5.2.  Briefly the problem occurs when the DMM
synchronizes with the LDAP server and there have been changes to the LDAP users.
As a result the DMM removes the admin users from the admin role list.
I have tested this in 5.2 and it is resolved.
There is no real workaround for this.  If you can not upgrade at this time, you can minimalize
the effect by either doing manual LDAP synchronization or schedule longer intervals between
synchronization which may require some role fixing after the synchronization.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Linda,
My apologies.
Thank You!
T.
Thank you Tomas.
We are hoping to upgrade to version 5.2 this Thursday so hopefully this issue will be resolved as you stated.
Many thanks
Linda
418
