DMM SMTP non port 25
New installation of DMM 5.2
Customer's smtp server does not use port 25 to accept mail.
Is there a way to tell DMM to use a different port?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: DMM SMTP non port 25
Please log in to your DMM appliance and start DMS-Admin. Then, do the following.
Configure  SNMP Server Settings for Your DMM Appliance
Cisco DMS  can convey its notifications to an external SNMP server.
Procedure
Step 1 Choose Settings > SNMP.
Step 2 Click the Server Status radio button to enable or  disable SNMP monitoring.
Step 3 Enter in the Host field the routable IP address or  DNS-resolvable hostname of your NMS.
Step 4 Enter in the Port field the numeric UDP port  assignment reserved for SNMP traffic.
Step 5 Apply the community string.
a. Enter in the Community String  field the password to identify that community.
Tip The default Community String  value is public.
Step 6 Click Save.
Step 7 Stop. You have completed this procedure.
Procedure
Step 6 Click Save.
Bronze
Log into the DMM Web-GUI and Navigate to Administartion Module --> Settings --> SMTP and configure the Server IP address and custom port number.
Hope this helps.
Sagar Dhanrale
561
