Community Member
DMP 4305G and 4400 Kernel upgrade
I am using DMP 4305G and 4400 in standalone mode. I need documentation on how to upgrade the Kernel on DMPs when used in standalone Mode (without a DMM). I got the following instruction from Cisco, but when I did this, I got a blank page, no response. How to you verify the Kernel upgrade was successful? Thanks for your help.
1) host the kernel image on a webserver and get the link to that image
> (i.e. http://10.10.10.10/DMPkernel_A1_4300.tivella)
> 2) Next, open a web browser and put the following in your
> browser:
> http://<ip address of
> dmp>:7777/set_param?mng.command=start+upgrade+kernel+<url from #1>
> (example:
> http://10.10.10.2:7777/set_param?mng.command=start+upgrade+kernel+http
> If you've already upgraded the firmware to 5.2 then the above links
> need to be 'https://<ip address of DMP>:7777'.
Jules
Re: DMP 4305G and 4400 Kernel upgrade
The procedure that you have is correct.
To check status of Upgrade:
* After the upgrade and DMP reboots use this command to check the status:
  http://admin:default@a.b.c.d:7777/get_param?p=init.upg*
Sample Response:
init.upg_context              T_STRING            Upgrade  (kernel) succeeded
What version of firmware are you running on DMP?  Please provide a screen snapshot of Hardware & Firmware screen from the DMP-DM webpage.
Community Member
Thomas,
Thanks for your interest to resolve this issue. Version is 5.2 and Hardware is DMS-DMP-4305G-DS. I have resolved it by adding the MIME-type .tivella extension (as text/plain) in IIS to allow the upgrade file to be served by the web server. The upgrade was successful. Thanks again.
Community Member
Thomas,
Do you have a list of DMP commands or a link of the documentation containing DMP commands via Web  GUI such as http://admin:default@a.b.c.d:7777/get_param?p=init.upg*? I cann't find that on Cisco site.
Jules
You can register here:
http://developer.cisco.com/web/dms/home
the DMS API Guide is here....
cheers!
T.
1417
