DMP 4305G FTP upload
arudolph_emd
Hello -
I have a DMP-4305G that I am trying to upload a .swf file to via FTP.  I am able to FTP files to the root directory, but but the files put here get deleted on reboot.  I need the file to be in the usb_1 directory so it is kept after a reboot.  I am able to do this on 4 other DMP's of the same hardware and software versions with no problem.  I have the FTP server turned on and the internal storage is set to "Read and Write".  When I try to upload a file to the usb_1 directory, I get "552 Could not create file."  Does anyone have an idea what would be causing this?
Thank you.
Tomas de Leon
Andy,
What DMS version are you running of DMP?
Also, please run this MIB and paste results into a text
file and upload it here.
VARIABLES
admin    = DMP Web Account Username
default  = DMP Web Account Password
a.b.c.d  = IP Address of DMP
Status MIB
https://admin:default@a.b.c.d:7777/get_param?p=*.*
After posting the output of the status mib,
Goto DMP-DM Web Gui interface and please perform the following:
* Under Administration section, select "Restore Default Settings" and press Restore
   The DMP should reboot.
* After Reboot, HTTP back to the DMP-DM and reconfigure all the necessary parameters.
  Make sure you enable and configure passwords for FTP.  Other parameters: enable caching,
  change permissions to flash\cache to read write. etc...
* Apply all changes and then make sure you SAVE configuration.
  Reboot to make sure any changes are operational.
* Test FTP tasks and reboot and see of the issue comes back.
Just let us know!
T.
Thanks for the respones Tomas.  I think I have a bad unit.  I came in this morning and was going to try this, but I can't web or FTP to the DMP at all now.  I tried resetting with the button on the back also, but it just has the red and green lights on now and doesn't even give a splash screen when booting up.  Looks like it's time for a call to TAC.
