Community Member
DMP 4305G FTP upload
Hello -
I have a DMP-4305G that I am trying to upload a .swf file to via FTP.  I am able to FTP files to the root directory, but but the files put here get deleted on reboot.  I need the file to be in the usb_1 directory so it is kept after a reboot.  I am able to do this on 4 other DMP's of the same hardware and software versions with no problem.  I have the FTP server turned on and the internal storage is set to "Read and Write".  When I try to upload a file to the usb_1 directory, I get "552 Could not create file."  Does anyone have an idea what would be causing this?
Thank you.
Everyone's tags (3)
Re: DMP 4305G FTP upload
What DMS version are you running of DMP?
Also, please run this MIB and paste results into a text
file and upload it here.
admin    = DMP Web Account Username
default  = DMP Web Account Password
a.b.c.d  = IP Address of DMP
Status MIB
After posting the output of the status mib,
Goto DMP-DM Web Gui interface and please perform the following:
* Under Administration section, select "Restore Default Settings" and press Restore
   The DMP should reboot.
* After Reboot, HTTP back to the DMP-DM and reconfigure all the necessary parameters.
  Make sure you enable and configure passwords for FTP.  Other parameters: enable caching,
  change permissions to flash\cache to read write. etc...
* Apply all changes and then make sure you SAVE configuration.
  Reboot to make sure any changes are operational.
* Test FTP tasks and reboot and see of the issue comes back.
Just let us know!
Community Member
Thanks for the respones Tomas.  I think I have a bad unit.  I came in this morning and was going to try this, but I can't web or FTP to the DMP at all now.  I tried resetting with the button on the back also, but it just has the red and green lights on now and doesn't even give a splash screen when booting up.  Looks like it's time for a call to TAC.
