02-25-2014 04:10 AM - edited 03-15-2019 05:28 AM
According to our "Video" guys, the DMP 4310G should not use PoE when an external power source is conneced.
From my point of view (the switch view) that is not really what is happening.
The DMP is starting flapping between PoE and non-PoE every second when it's connected to a PoE-enabled port
313757: Feb 25 10:54:37.569 CET: %ILPOWER-7-DETECT: Interface Fa0/11: Power Device detected: IEEE PD |
313758: Feb 25 10:54:38.123 CET: %ILPOWER-5-POWER_GRANTED: Interface Fa0/11: Power granted |
313759: Feb 25 10:54:40.631 CET: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/11: PD removed |
313760: Feb 25 10:54:41.512 CET: %ILPOWER-7-DETECT: Interface Fa0/11: Power Device detected: IEEE PD |
313761: Feb 25 10:54:42.175 CET: %ILPOWER-5-POWER_GRANTED: Interface Fa0/11: Power granted |
313762: Feb 25 10:54:43.500 CET: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/11: PD removed |
313763: Feb 25 10:54:44.507 CET: %ILPOWER-7-DETECT: Interface Fa0/11: Power Device detected: IEEE PD |
313764: Feb 25 10:54:45.505 CET: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/11: PD removed |
313765: Feb 25 10:54:46.503 CET: %ILPOWER-7-DETECT: Interface Fa0/11: Power Device detected: IEEE PD |
313766: Feb 25 10:54:47.166 CET: %ILPOWER-5-POWER_GRANTED: Interface Fa0/11: Power granted |
The quick fix for this is to issue the power inline never on the switchport. But my question is why is the DMP not behaving as i should? Why is it requesting PoE every second if it should not use it?
Any thoughts?
Johan
02-25-2014 11:37 AM
1- Cisco DMP is POE , which can be power up using Cisco switches POE .
2-Cisco DMP supports 802.3af PoE .
3-Cisco DMP requires about 15.4 watt
4-Check the cable , may be you have packet loss .To check cable is ok or n , check the following
https://supportforums.cisco.com/docs/DOC-18983
5-Basically the cause of this Message is output in the following condition.Imax error is reported by PoE controller of the switch, when a PoE PD device misbehavesand draws more power ( Port Current ) beyond theirs specified limit.
Imax error is reported after the device is Powered up and it's an operating fault.Usually that message can happen when new PD (power device) is connected and cause thepower spike on port, or PD is mis-behaving or there is a problem with cable or patch panel.
6- Check the DMP for other switch and check again.
7- If you have stack between switches , check may be you have stack flapping.
Can you have a look
Please rate all useful information
02-25-2014 11:40 AM
hi
Try the below commands to disable the logs , and do not wory these logs will not affect your environment
(config)#logging discriminator ILPOWER msg-body drops ILPOWER-7-DETECT
(config)#logging console discriminator ILPOWER
(config)#logging buffered discriminator ILPOWER
I hope also to check the power , # show power inline
thanks
02-25-2014 12:04 PM
Hi and thanks for your reply!
Yes, great generel info about PoE. But still, we have external power supply connected so the DMP should never try to negotiate for PoE, right?
I have not checked the cables, but this problem is for all our DMP's, so I guess that almost ruled out to.
Sure, we can filter out the logs, but I'm not looking for a quick dirty fix, I want to find the root cause of the misbehaving PoE device.
Is there a setting in the DMP that can turn off PoE?
Again, thanks for your efforts.
Johan
02-25-2014 12:38 PM
1- Nothing to do on Cisco DMP , you have to disable POE from switch side as you mentoned above.
power inline never
or
no power inline
Please rate all useful infomation
02-25-2014 12:39 PM
conf t
interface f0/11
power inline never
02-25-2014 12:45 PM
I forgot one important issue , which cause your issue. When both PoE power and AC power are detected, AC power overrides PoE and disconnects the PoE circuit .So switch detect a poe device and power .
Please rate all useful infromation
02-25-2014 09:55 PM
Hi Leo and Islam.
As I wrote in the initial post, power inline never, is not what I'm looking for.
We use DMP's on switchports with dynamic vlan assignment, therfore I need to keep the switchport configuration as generic as possible. If I use power ineline never, then I can promise that I have a ip-phone on that port next week that won't boot.
The problem with the logs is that is not one or two log entry. This PoE flapping is happening almost every second as the DMP is connected and therefore creates thousands of log entrys each day.
Don't you agree on that it is the DMP that is causing this problem and should be fixed within the DMP?
02-26-2014 12:47 AM
I am suspecting there's a bug with the DMP firmware where the appliance can't make up it's mind to accept the source of power.
03-01-2014 05:50 AM
Okey
Thanks for your help Islam and Leo
Johan
03-07-2014 09:34 PM
Robert,
They are bought from a system integrator. I've been told they have created a case but haven't seen any output from it.
Sure I can test with 15.0.2 but that is nothing that will be but in the prodution network, we rather looking into downgradeing to 12.2.55 due to an upcoming ISE integration.
Leo,
The site with several DMP's has a newly installed and certified Category 7 cabling. I don't say that it's impossible but I really don't think that the cabling is the issue. As I wrote in the previous post, we have the same problem on another site to.
The interface is not going up/down, it's just the PoE that is flapping, this is happening almost every second. The DMP is woorking fine during these flaps, it does not reboot.
Johan
07-30-2014 06:47 AM
Just to add that we also had the same problem. Installed three DMP 4310s with external power and one never had a problem, one had serious flapping. We choose to disconnected the external power.
08-01-2014 10:07 AM
hello
yes , completely true . This is a good idea to solve issue when you player connected to poe switch. you can also go to switch and disable power as below suggestions. It is very important to do a survey before take a decision to purchase charger or not and this is based of your existing switches (poe support or not).
please rate all useful information
