DMP 4310G Remote Keys
Trying to setup the color keys on the DMP 4310 remote to switch between CAST and playlist. Have it working fine on DMP 4400G and used the instructions from DMP4310-map-remote-buttons.docx (https://supportforums.cisco.com/document/81906/dmp4310-map-remote-buttonsdocx), but the keys do not seem to invoke anything. Have tried firmware 5.2.2.3 and 5.4. Confirmed each step of the DMP4310-map-remote-buttons.docx and .dmp files are on the DMP and get_param?p=irasrv.key* shows the commands are assigned to color keys. Confirmed stings when applied through browser to DMP change between CAST and playlist.
There is just no indication that the DMP has received anything when the color key is pressed, unlike the DMP 4400 were it tells you a key is not bound.  Pressing help does bring up the show IP so the remote is working.
irasrv.key_GREEN T_STRING ira add 1 shell 1 GREEN mng write sh bg /tmp/ftproot/usb_1/signage.dmp
irasrv.key_RED T_STRING ira add 1 shell 1 RED mng write sh bg /tmp/ftproot/usb_1/cast.dmp
Everyone's tags (4)
1 REPLY
Ok and least I know the
Ok and least I know the remote color keys are working as I set one to show IP with
https://dmp.address:7777/set_param?irasrv.key_YELLOW=ira+add+1+shell+1+YELLOW+mng+write+ciscocraft%20showIP%7B%7D&mib.save=1
-rwxrwxrwx    1 ftp      ftp           480 Mar 31 12:54 cast.dmp
-rwxrwxrwx    1 ftp      ftp           536 Mar 31 12:54 signage.dmp
https://dmp.address:7777/get_param?p=irasrv.key*
irasrv.key_YELLOW T_STRING ira add 1 shell 1 YELLOW mng write ciscocraft showIP{}
269
