DMP 4400 and 4305 in 5.1
Hi Tomas
I'm using DMP 105, of which 20 are 4400 and 85 are 4305g. In all we've set the resolution in the Screen Width 1920 x Height 1080. The video sources used were created in SD and HD. When played on the DMP, the video is not visulizado, leaving a black screen. If the DMP's configured in 1366 x 768, the video is played OK. With 1920 x 1080 resolution web pages work ok.
If I have to change all this resolution dmp causes me more problems than are It Works web pages with information and configured with this resolucion1920x1080.
The videos are in format MPEG2_TS
I wish I had an urgent response because this customer is to buy 100 more DMP 4400
2 ACCEPTED SOLUTIONS
Re: DMP 4400 and 4305 in 5.1
Claudio,
Can you please provide the following so we can look
at the possible issues?
From a DMP that is experiencing this issue.  Access the
DMP-DM Web interface and get snapshots of the following
screens:
* Settings-->Browser
* Settings-->Display Attributes
* Settings-->DMP Display Dimensions
* About-->Hardware and Firmware Versions
Then, Download Media Info and use this tool to get the
"text" output of the media info of the Video file having
the issue.
* http://mediainfo.sourceforge.net/en
Please post or attach the text output of the Video file.
Hopefully, after getting this info we can narrow
down the issue.
T.
Claudio,
Thank you for uploading the screen shots but you did not upload
the media info of the video file.
Also,  please recapture the "DMP Display attributes"  it appears the
HDMI information was cutoff or incomplete.  Should see one that is like
the one I attached.
Also, What is the exact Model number of the Samsung LCD?
thanks
T.
Claudio,
screens:
the issue.
down the issue.
T.
Hi, Tomas.
I send you the info I asked for. Are the screen captures of DMP, the failure does so from the DMP or from a Web server. you can use any video in HD for testing. Remember that if the DMP is set to 1366x768 works, but if the dmp is in 1090x1080 does not work.
Claudio,
the one I attached.
thanks
T.
I also noticed a couple things:
* One you have autodetect enabled for Display attributes and disabled for Browser settings.
   Try synching both as Autodetect enabled or disabled.
* Another thing which maybe be the issue is the "FrameRate" you currently have 60hz.  Try
setting it manually to 59.94hz  apply, save, & reboot...
T.
Hi Tomas
Excuse the delay, I send the dmp catches again. authorize my client let's you video. The model of LCD / TV is Samsung 40 ° HD LN40A550P1R.
DMP 4400 can be modified so that you indicated in the previous note, but in the DMP 4305g can not be modified
Thanks Tomas.
Hi Tomas,Today I could edit the original video that has a size of 174MB and the support site makes up only 50mb, so I send you a short video for you to try.
add another minute video mensaje1m.zip
thank you very much Claudio.
Claudio,
I have tested the video files that you uploaded and
I have no issues playing them out.
Please refresh my memory what is exactly wrong with
these files?
I have tested with a playlist configured for:
1920x1080
1366x768
thanks for the files to test!
T.
Ok, Tomas
It's the video, but Link Remember that is only part of the video, dmp are set to 1920 x 1080 and the version we use is 5.1
Claudio.
548
