DMP 4400 conversion
Need to play some video files from DMP, but not sure what is the right format and which tool to use.
This video plays correctly:
ffmpeg -i <video file>
Input #0, mpeg, from 'ATT_Telepresence_Scheduling.mpg':
  Duration: 00:07:14.08, start: 0.522456, bitrate: 474 kb/s
    Stream #0:0[0x1e0]: Video: mpeg2video (Main), yuv420p, 600x340 [SAR 1:1 DAR 30:17], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
    Stream #0:1[0x1c0]: Audio: mp2, 44100 Hz, stereo, s16p, 128 kb/s
This file does not play:
Input #0, mpegts, from 'Telepresence_part2.ts':
Duration: 00:02:32.83, start: 1.000000, bitrate: 8783 kb/s
Program 1
Stream #0:0[0x45]: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 163 kb/s
Stream #0:1[0x44]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 29.92 fps, 29.92 tbr, 90k tbn, 59.82 tbc
How to perform the conversion to mpeg and to video mpeg2video and audio mp2?
Everyone's tags (3)
DMP 4400 conversion
It's probably because that file ends in a .ts extension.  Try changing the .ts to .mpg.
DMP 4400 conversion
I tried this command and worked fine:
ffmpeg -i
inputfile
-codec:v
mpeg2video
-qscale:v 2 -codec:a
mp2
-b:a 192k
outputfile.mpg
433
