04-12-2010 02:10 PM - edited 03-13-2019 06:56 PM
Hi, i´m testing the dmp with an lcd from samsung. I´m using the rs-232 port just to turn on and off the monitor.
I have same questions:
1- wich rs-232 cable should be used straight? null-modem? The documents i checked do not mention that.
2- I was testing it with my pc first instead of the dmp, 9.6k 8n1 no flow control, with no sucess.
3- Hexa commands for Samsung lcd, there is a table?
Thanks for any lead.
Carlos
Solved! Go to Solution.
04-26-2010 10:07 AM
I believe it is a null modem cable. That has worked for me. I have attached a PDF that I found that describes how to create RS232 hex commands for Samsung displays. I have tried a few from this list and they worked for me.
04-26-2010 10:07 AM
04-26-2010 10:52 AM
I also Used an RS232-cross cable and work for me.
db9 female db9 female
5 (GND) -----------------------------------------5 (GND)
3 (TX) ------------------------------------------2 (RX)
2 (RX) ------------------------------------------3 (TX)
8 (CTS) -----------------------------------------7 (RTS)
7 (RTS) -----------------------------------------8 (CTS)
6 (DSR) -----------------------------------------4 (DTR)
4 (DTR)------------------------------------------6 (DSR)
Thanks for the Samsung Document.
Carlos
05-04-2010 02:14 AM
post deleted by me. Will make post new discussion.
