Showing results forĀ
Search instead forĀ
Did you mean:Ā
DMP 4400 wireless
itzcoatl.m
hello experts,
The question is whether the DMP 4400 needs an antenna to get the wireless working, in the DS doesnt say anything about it and cant find  anything related in the DMP's documentation any idea?
thank you for your answer
Marco Cassini
Indeed, the DMP 4400G has an antenna which needs to be screwed to the antenna jack in order to support Wifi. The antenna should be shipped together with the DMP.
In order to set up wireless connectivity you can refer to the following documentation:
http://www.cisco.com/en/US/docs/video/digital_media_systems/dmp/user/guide/5_x/5_2_x/network.html#wp1157593
I hope this helps.
Best Regards,
Marco
