DMP 4400G after upgarde "5.2_EFT_DMP4400G.fwimg" trouble
i have upgraded one dmp 4400G to 5.2 using "5.2_EFT_DMP4400G.fwimg" firmware,
every thing goes ok
upgrading, burnig, verifing, ok
but after the front light turns into green, no response from the dmp using the remote controle, can't show ip adress then can't acess the dmp for seting static IP, and more noting shows up using the remote control then what to do in this cas,
thank's
Re: DMP 4400G after upgarde "5.2_EFT_DMP4400G.fwimg" trouble
Raouf,
The DMP should have rebooted after upgrade.  On bootup, the DMP should
display a Cisco Splash screen displaying the IP Address.  When you reboot
the DMP, Is the Cisco splash screen displayed?
* What version of firmware did you upgrade from?
* Try resetting the DMP back to factory defaults and let us know what happens
   Press & Hold the RESET button (located on back of
   DMP 4400) for at least 10 seconds.  The DMP may emit an
   audible "beep" when it has hit the required amount
   of time.
The DMP should reboot and and display the Cisco Splash.  At this time the DMP
should be reset to factory defaults and you can access the DMP-DM to reconfigure.
Cheers!
T.
After updating to
5.2.1 I  had to pull the power on a few DMP to get them to wake back up.
then first off all thx's for the fast answer,
so those are the facts;
- The DMP was on 5.1 firmware, and was working perfectly,
i'm trying dmm 5.2 on vmware so i upgarded the dmp to 5.2 firmware
"5.2_EFT_DMP4400G.fwimg", i have upgraded the dmp before from 5.0 to 5.1 and every thing goes ok, so the same pathway was show on both the browser window and the hdmi screenconnected to the 4400G DMP, 1> burning, 2> verifiyng and 3> rebouting and a sucessessfull message apearse on both browser and DMP screen.
I triyed then reseting the dmp but no way no logo of cisco nor any thing on the screen, no acess from web browser to, but the front lights turns from red to green, i wonder if the wifi layer is still searching for ip adress than i plugen the antenna and also the external IR receiver to and triyed every thing but, nothing comes out, no logo, no remote control reaction nothing and the fact of reseting does not change any thing.
thx's
My apologies for the basic questions but i need to ask:
* what type of display do you have attached to DMP?
* how is it connected to the DMP, HDMI?
* Is there a signal to the Display? You should see something
when you power off and power the DMP.  For example, when
you power off\on the DMP the display should have no signal and
go into standby (amber light or something) and then once the DMP
turns on and restarts, the display should awake and (green light status
on the display should come on and stay on) then the splash screen
occurs.
* Try holding the reset button again for at least 30 seconds and see
if that makes a difference.
Since you were at 5.1, wireless shouldn't make a difference since
it is new to 5.2
Also, check you DHCP server to see if it getting an IP address. Since the
light goes green that indicates the DMP has an IP address.
T.
hi again,
so the details :
- Display : HP HDMI Screen ( HP w2228h )
- Connected ot the DMP 4400G by a HDMI wire
- The display detect the DMP so there is a signal but a black screen, so a back light is noticable on the display and it last for almost 1 hour
- i'm working connecting the DMP directly to the PC on wich i run a "DHCP server 1.9" so the same was working on the 5.1 firmware
for the last try
- i hold the reset for 2 minute, and the DMP continues to bip every 30 second but i hold the reste button, and after 2 minute, EUREKA, it worked again
a last information;
ater the reboot
when i changed the DHCP adress in to static ones the DMP Hoocked on the splash screen on witch cisco logo and ip adress
563
