DMP 4400G Synchronization Issue
I am facing a synchronization problem. I have  a wall of 12 DMPs connected to 12 LCD screens. Whenever I pull a video to those DMPs from the DMS, they are synchronized for maximum 1 or 2 minutes. After that delays occurs in between. After a while, it looks like each screen is playing alone.
Any ideas on how to solve this problem?
Thank you in advance.
Hi Houssam,
I'm afraid there is nothing you can do to solve this. The DMP don't have any synchronization mechanism, so if several are playing the same content, they will eventually loose sync.
I wish I could give you a more satisfactory answer.
Daniel
I have the same issue.  The best solution I've found is to program a single DMP to playback a scheduled presentation or playlist, output the video feed from that DMP into a live multicast stream, then program the other DMPs to tune to that stream.  It is a bit of a workaround but keeps them more or less in sync.
Todd
576
