Community Member
DMP Image (.ISO) for VM Use
Would like to work locally in a VM for much faster Flash API/dev purposes, is there any way to get an image of a 4310 install (the Linux/busybox image)?
Alternatively - is there a documented method for cross-compiling in the MIPS architecture required to execute binaries via SSH on the DMP?
Thanks!
Everyone's tags (4)
1 REPLY
Hi Chris,
I'm afraid the answer is "no" to both answers. The DMP firmware is highly dependent on the hardware and thus, cannot run on vmware, and using the SSH access for anything that is not troubleshooting under TAC guidance is not supported.
I wish I had better news for you.
Daniel
616
