DMP upgrade issue
I am having an issue with upgrading my
Cisco DMP.
I select the "Upgrade Firmware" on the
DMP-DM.
I browse my workstation and select the following
firmware file:
rootfs_2.43.1FCS_4305.fwimg
During the upgrade process I see the following
error in the Upgrade Status window:
"Invalid product tag (act:"D4305G", exp:"cmp")"
The Upgrade fails...
Re: DMP upgrade issue
The symptoms that you describe is typically seen when trying to upgrade a DMP with the incorrect FW Version.
In your case, it looks like you are trying to upgrade a DMP-4300G with the DMP-4305 Firmware.
Please verify that you actually have a DMP-4305G and not a DMP-4300G. From the DMP-DM under the ABOUT section, Select the"Hardware and Firmware Versions"
You should see something like:
Product DMP-4305G
Product ID DMS-DMP-4305G-DS
** Make sure the FW and the HW match...
You must have a 4300 instead of 4305. Download the image for 4300 by going to cisco.com->Support->Download Software->Video, Cable and Content Delivery->Digital Media Systems->Digital Media Players->Digital Media Players 4300G
802
