Fail DMM 5.2.3 in clustering mode
Dear all,
We have a problem when try to Activate the cluster in the Failover Configuration window.
We have upload the clustering module license & the base license in both of the servers
DMM-SVR-C210-K9
DMM-FA-C210-K9
...but when I click in the Activate button appear this error:
Sending Request
"No cluster Activaton in progress"
[Activate]: Publishing configutation to X.X.X.X failed
This is my configuration:
SRV
Set as Master: Name: DMM Cluster
Primary FQDN: bv01.test.com
Secondary: bv02.test.com
Virtual FQDN: bv.test.com
FA
Master FQDN: bv.test.com
Clustering Status: Unconfigured
Replication interface Crossover
Thanks.
1 REPLY
I find in the FAQ this:
Q: What does the error message "Unable to publish cluster configuration to node" mean?
A: The cluster configuration cannot be pushed to the specified node. The most likely cause for this is that the cluster master has not been set on that node
...But I checked the
Cluster master set to bv.test.com
in the second node and the crossover cable is correctly conected and appear the same message:
[Activate]: Publishing configuration to X.X.X.X failed
Any idea?
697
