file on DMP is missing when deploy using DMM
I have a DMM and DMP on my network,  for some reason I put a file '.xml' on my DMP in folder content (http:\\tmp\usb_1\deployment\content\\...) and folder x-tac core too.
the problem is when I deploy a presentation using dmm to dmp the file xml that I store is MISSING,
the question is why the file xml gone ? I want this file is still there when I Deployment Package via DMM to DMP.
Thanks in advance for any advice you may have.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hi Andrie,
That folder is reserved for the deployment package, so, any files already present will be deleted when you do a deployment.
When you deploy a presentation or playlist, the DMM will push all the content required for that presentation, so, I'm afraid I don't really see the point of trying to upload a file manually, but, if you really want to do it, you can upload it after the deployment has finished or just put it in a different folder.
Daniel
Hi Andrie,
Daniel
Hi Daniel,
nice info gan, so the file I put in a diffrent folder and order my develop to modify the swf application..
my problem solve,
Thank!.
699
