Community Member
FIXED: I now have a Trial/Test License for Upgrade Test in Lab
I have a couple DMM servers at version 5.2.3, and I need to test the ability of 5.4 to work with our InformaCast Server.  I installed the 5.4 VM on ESXi, but I need a license to get the VM to send media output to a DMP in my lab setup.  I currently have 60 DMP licenses (30, plus 10 pack, plus another 10 pack), but I'm only using 39 of them, so maybe I could use one of my 10 packs which are currently on my production DMM server -- assuming I could later UNinstall them from the lab and put them back on my production box?
UPDATE:  I have the license now.  I think I should probably post a separate discussion thread now, because I realize I need to have the DMP on the same major version of software, but I'm not sure if I can downgrade after an upgrade to a DMP (in case the server is not going to work for us, at the new version).
Message was edited by: Paul Richardson
Everyone's tags (5)
Community Member
Re: FIXED: I now have a Trial/Test License for Upgrade Test in L
You can downgrade a DMP the same way you upgrade it. Just select the older version of code for your player when you have finished testing in your lab environment.
