Community Member
Flash Clock and calender or Javascript clock
I created a Flash clock and current date display but it reads january 1 1977 and the clock is way off. I believe this is UNIX time, I have tested my code online and it works great but once I run it from the dmp it resorts back to the time and date stated above. Does anyone know a way around this?
Jason
PS
I also wrote a javescript that does the exact same thing.
Community Member
Re: Flash Clock and calender or Javascript clock
Which DMP model/firmware are you using? ASFAIK, you must use firmware 5.2 to allow a change to the internal clock in a DMP.
Community Member
-Thanks for the info, I am running an older version of the firmware.
Actaully, now that I think about it Im running the 4305g with the lates firmware upgrad...So would this only be available in the 4400's?
Community Member
I am not 100% sure. I don't believe though that the older DMPs had an internal clock altogether. If you confirm, please share.
355
