Community Member
How do i receive input from remote control? (DMP 4310)
I am developing the content on DMP 4310g which have to developed by flash action script 2.
I can play video and any text following a manual attached with this discussion.
The problem is there is no the idea about remote control on that manual.
Can any provide some solution or manual?
Everyone's tags (4)
Bronze
Can you rephrase your question ? Are you trying to use the remote control on the 4310 to change the presentation on the display ? Are you looking for a remote key mapping document for 4310 ?
Sagar
Community Member
->yes, i am trying to use the remote control to change the presentaion on the display.
   My presentation is a button list that can be pushed when you push the button on remote control.
   My actionscript is a key listenner that will be fired when key down.
Bronze
Attached is the document that will assist you achieve the mapping on Remote keys in "4310" to a particular function, like assigning the red key to play CONTENT A, BLUE key for CAST etc ,
It may assist you somewhat and you can tweak it to your needs. I believe your scenario is different - more of a content creation issue, you want the remote key to control an asset and simulate a button press in your presentation, I'm not sure how that can be achieved or if the document can be helpful there but you can try.
Note : The process assumes you have a Web Server - Apache or IIS.
Sagar Dhanrale
Document :
https://supportforums.cisco.com/docs/DOC-20631
Community Member
The link to this document https://supportforums.cisco.com/docs/DOC-20631 is no longer valid.  Does anyone have this document that could repost or send to me?  Thanks.
-Adam
Community Member
Hi Adam
I think you should find them in one of the two PDFs in the zip I have upload for you:
https://www.dropbox.com/s/298vnooqyci0tlh/DMP4310.zip
Cheers
Ali
1934
