How to control an LCD by RS-232???
In the User's guide there is a list that shows the commands to control Cisco 40" and 52" LCDs (page 14-34). Where can I find the same info for a Cisco 32" and other brands, for example I have a 3200L ÉLO touch screen.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: How to control an LCD by RS-232???
The Cisco Displays can be controlled via:
* the TV Controller (little TV icon - screen attached)
* Advanced Task (screen attached)
as for the ELO, you will need to contact ELO to see if you
can get the rs-232 control codes if they are available.
Once you get the codes you need, you can simply add
an Advanced task to control the ELO or any other Non
Cisco Displays if they can use RS232 for control.
T.
1 REPLY
T.
432
