Community Member
Issue with Media URL display in 4305G
I can run a mpeg URL if it is posted in Media URL within DMP by clicking Start but if I try sending the same URL either through Startup URL or as a Job I get an error "Write enable the disc or try different folder."
Everyone's tags (3)
Re: Issue with Media URL display in 4305G
Pankjb,
What is the format of the Video Content?
What is the sample URL that you are using?
What DMS-DMP version are you running on the 4305G?
In 5.2,  There is a Startup "Media" & "Browser" URL.  For "video" content you need to use
the MEDIA URL.  I have tested and it works fine.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Community Member
What is the format of the Video Content? MPEG.
What is the sample URL that you are using? http://10.1.10.10/test.mpeg
What DMS-DMP version are you running on the 4305G? 5.2
In 5.2,  There is a Startup "Media" & "Browser" URL.  For "video" content you need to use the MEDIA URL.  I have tested and it works fine.
Yes when I paste this url in Dispaly Actions --> Media URL and press Start works fine. But the same URL I try to submit using Go To URL it gives error "Write Protected". If I give the same as Startup URL in Media - no display.
Please provide screenshots of the following screens from
the DMP-DM:
* Settings->Basic
* About->Hardware and Firmware Versions
You mention:
"But the same URL I try to submit using Go To URL it gives error "Write Protected"."
There is no "Go To URL" setting where are you seeing that?
thanks
T.
653
