Live event: same channel same port fail to stream two differ stream type
Hi All,
When I create live event in same channel and same port with differ type streaming  (unicast and multicast) I can’t start DME so I cannot  start broadcast too and video cannot stream..
I did try and used non-dme live event .. the result still same and video not stream in sns. Im ussualy use this way with last dmm version (5.0.2) and to day I use SnS ver 5.2.1 its not running/ video blank......
anybody know what happening ???
thanks
RD
Everyone's tags (2)
1 REPLY
Re: Live event: same channel same port fail to stream two differ
RD,
Lets step back a little and get some more details:
* What type of DME are you using?
* What is connected to the DME providing the LIVE stream?
* Specifically, how do you have the DME configured for your setup?
* Please provide the SCREEN CAPTUREs of your DME configuration on
the SNS
* Have you configured a "Basic" configuration (single channel\port only) on the DME
and SNS with 5.2.1 and have it working?  Have you ever got the DME working with SnS 5.2.1
Thanks!
T.
410
