Multicast stream to DMP from DMM
I am using a Qvidium encoder to create a multicast stream. If i go into the web interface of the DMP, I can play the multicast stream.  I would like to put that stream into a presentation and send it to the DMP, and play the stream inside a video play list.  Any help on this would be wonderful.
Bill
Re: Multicast stream to DMP from DMM
I am having the same issue. Any help is much appreciated.
Jeff
Jeff,
Good news, I have been able to supply a multicast stream to a video playlist inside a presentation.  I had to create a UDP video asset with the following url:
udp://239.20.20.1:1234?multicast
obviously the IP address of my stream and port will be what ever you set it to, but adding the ?multicast is what turned it on for me.
Hope that helps.
Bill
1166
