Community Member
Non Scientific Atlanta Encoder for DMP 4400
Could I use a non scientific atlanta encoder for stream video to a DMP 4400G? I'm thinking about purchase an encoder with this video specifications:
Codec vídeo: MPEG-2 MP&ML, MPEG-4 ASP
Codec audio: MPEG-1 Layer II
Output rate: up to 100 Mbps
Protocol: UDP/RTP
Simultaneus Streams  2
Multicast Yes
Could I use it?
Thanks.
1 ACCEPTED SOLUTION
Re: Non Scientific Atlanta Encoder for DMP 4400
A non SA encoder can be used as long as the following specifications is met:
Video Codecs:
• Video MPEG1
• Video MPEG2: Main Profile at High Level
• Video MPEG4 Part 10 Baseline and Main profiles
Video Containers:
• MPEG Transport Stream (TS, TP, TRP, M2T, M2TS, and MTS)
The key here is the Video Container.  Check to make sure
that MPEG TS is supported.  If so you are good to go....
Before buying one, have the salesman bring one onsite for a demo and
test with the DMP.  Once you test successfully then you can proceed with
the purchase.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Video Codecs:
• Video MPEG1
Video Containers:
the purchase.
Thank You!
T.
Community Member
Thanks Tomas.
615
