Power Supply for 4400G
Lost power supply for DMP 4400G, Can anyone tell me what the Cisco part number for just the power supply?
Or if I go the local geek store to get one, I found specs calling for a 12V, 300 mill amp power supply but It did not say if the center pin of the power plug is positive or negative, any ideas?
1 ACCEPTED SOLUTION
Re: Power Supply for 4400G
Randy,
Try this part#
DMP4400-ACC-KIT=
You should be able to order this one...
Sorry for the confusion
T.
For the DMP-4400G:
Part# is DMP-4400-ACC-KIT=
         (Accessory Kit)
For the DMP-4305G:
Part# is DMS-DMP-4300G-KIT
NOTE: The ACCESSORY KIT does come with the Power supply
for the DMP.  However, the power cable is a separate
configuration item that needs to be ordered separately.
I hope this helps!
T.
Our Cisco reseller said that the part listed is a $0 item that can not be ordered on it's own, it can only be included if we order the DMP.
I also e-mailed our Cisco sells person who's response was "apparently we dont sell the power supplies separately".
Randy,
Try this part#
DMP4400-ACC-KIT=
T.
1118
