Community Member
Remote Button Programing
I'm able to program the remote buttons with no problem but, i have over 60 DMPs deployed and would like to be able to program them all at once.  Is there a way in the DMM to write an advanced task app that will program the button remote?
Al
2 ACCEPTED SOLUTIONS
Re: Remote Button Programing
Alan,
here is a tech tip that I wrote on programming the buttons on the remote via
a HTTP mib.  Just create an Advanced Task under the System task
for each colored button.  Test & verify it works on a single DMP first and
then send task for each colored button to all of the DMPs.  Once this is
completed make sure you SAVE the configuration.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
You can use DMP MIBs to reconfigure the DMP Remote Buttons.
VARIABLES
  admin           = DMP Web Account Username
  default         = DMP Web Account Password
  a.b.c.d         = IP Address of DMP
  dmm.company.com = FQDN of the Digital Media Manager(DMM) Appliance
MIBS
** Use the Following MIB to see the CURRENT Remote Mappings
https://admin:default@a.b.c.d:7777/get_param?p=*.*&init.pop_enable=false
** Configure Buttons
RED
https://admin:default@a.b.c.d:7777/set_param?irasrv.key_RED=ira%20add%201%20sh%201%20RED%20bg%20wget%20-q%20%22localhost%3a7777%2Fset_param%3Finit.BROWSER_CMD%3Dwww.cisco.com%22
GREEN
https://admin:default@a.b.c.d:7777/set_param?irasrv.key_GREEN=ira%20add%201%20sh%201%20GREEN%20bg%20wget%20-q%20%22localhost%3a7777%2Fset_param%3Finit.BROWSER_CMD%3Dhttp://www.google.com%22
YELLOW
https://admin:default@a.b.c.d:7777/set_param?irasrv.key_YELLOW=ira%20add%201%20sh%201%20YELLOW%20bg%20wget%20-q%20%22localhost%3a7777%2Fset_param%3Finit.BROWSER_CMD%3Dhttp://www.yahoo.com%22
BLUE
https://admin:default@a.b.c.d:7777/set_param?irasrv.key_BLUE=ira%20add%201%20sh%201%20BLUE%20bg%20wget%20-q%20%22localhost%3a7777%2Fset_param%3Finit.BROWSER_CMD%3Dhttp://www.apple.com%22
ASSIGN A BUTTON TO CAST
https://admin:default@a.b.c.d:7777/set_param?irasrv.key_RED=ira%20add%201%20sh%201%20RED%20bg%20wget%20-q%20%22localhost%3a7777%2Fset_param%3Finit.BROWSER_CMD%3Dhttp://dmm.company.com:8080/etv-flash-webapp/app/etv_24_.htm%22
** Use the Following MIB to see the NEW CONFIGURED Remote Mappings
** Save NEW CONFIGURED Remote Mappings on DMP
   -> Use the ADVANCED TASK to SAVE the DMP Settings.
   -> or Directly on the DMP using the DMP-DM Web Admin
   -> or HTTP MIB
         ie.
         https://admin:default@a.b.c.d:7777/set_param?mib.save=1
         https://admin:default@a.b.c.d:7777/set_param?mib.save=1&mng.reboot=1
Try this string to set the YELLOW button and then you can use this
as a template:
Notice: in your string you are NOT escaping the RESERVED codes.  Per URL addressing spec RESERVED
characters need to be escaped.
I hope this clarifies this.
Also, test your string in the browser first and then you only add the request after set_param?
Cheers!
T.
Alan,
Thank You!
T.
VARIABLES
MIBS
RED
GREEN
YELLOW
BLUE
   -> or HTTP MIB
         ie.
Community Member
Thanks for the quick response.
I have tried this string in the app and i must be missing something.
request typ to "set"
request irasrv.key_RED=ira add 1 sh 1 RED bg wget -q "localhost:7777/set_param?init.BROWSER_CMD=http://a.b.c.d:8080/xTAS-core/appgen/clad/clad_158_.htm"
a.b.c.d = ip address of server
much appreciated.
as a template:
Cheers!
T.
Community Member
Hi Tomas,
May I know how to send an HTTP MIB request to a certain DMP to simulate a "remote" key click if I don't now have a remote handy. Say I want to test the Yellow button after it is programmed. I heared there was a remote simulator application out there but don't know how to get it?
768
