Routing Multicast Test
I've been testing multicast with DMPs in version 5.2 and VLC.
I have two VLANs: VLAN vlan 20 and 30, my VLC Server is in the vlan 20 and streaming reaches the DMPS that are in this vlan.
The vlan 30 I do not get any streaming.
Attached the configuration I have in my switches:
ip multicast-routing
ip multicast multipath
interface Vlan20
description "DMS1"
ip address 10.9.2.254 255.255.255.0
ip pim sparse-dense-mode
ip cgmp
interface Vlan30
description "DMS2"
ip address 10.9.3.254 255.255.255.0
ip cgmp
Anyone know any extra configuration or something I see missing out?
Greetings and thanks
Aurelio Zavaleta
Re: Routing Multicast Test
ip multicast-routing distributed
! change -> ip multicast-routing
! remove -> ip multicast multipath
interface Vlan20
description "DMS1"
ip cgmp
interface Vlan30
description "DMS2"
ip cgmp
Please provide the display output for
the following commands:
#sh ip multicast
#sh ip multicast interface vlan 20
#sh ip multicast interface vlan 30
T.
Hi Tomas
I tested with the command that you suggested, but I have not been successful.
Annex the configuration of the switch.
Aurello,
Why do you have the switch ports in VLAN 20 & 30
when your interface VLANs and Multicast interfaces are VLAN 200 & 300?
The Switch ports should be VLAN 200 & 300 not 20 & 30
T.
Hi Tomas
I changed the number of interfaces vlan in my lab.
I change the 200 vlan 20 and vlan 30 for 300.
But the problem continues.
This is my current configuration.
interface GigabitEthernet4/5
switchport access vlan 200
switchport mode access
media-type rj45
interface GigabitEthernet4/6
switchport access vlan 300
media-type rj45
interface Vlan1
no ip address
interface Vlan200
ip address 100.9.2.254 255.255.255.0
ip cgmp
interface Vlan300
ip address 100.9.3.254 255.255.255.0
ip cgmp
Switch#sh ip multicast interface vlan 200
Vlan200 is up, line protocol is up
  Internet address is
  Multicast routing: enabled
  Multicast switching: fast
  Multicast packets in/out: 3185688/0
  Multicast boundary: not set
  Multicast TTL threshold: 0
  Multicast Tagswitching: disabled
Switch#sh ip multicast interface vlan 300
Vlan300 is up, line protocol is up
  Internet address is
  Multicast packets in/out: 8/0
interface FastEthernet2/10
interface FastEthernet2/11
interface FastEthernet2/12
interface FastEthernet2/13
interface FastEthernet2/14
interface Vlan200
ip address
ip cgmp
interface Vlan300
ip address
ip cgmp
** change the VLAN 20 & 30s to VLAN 200 & 300
HI Aurelio,
I am providing you with our configuration (in case that helps),
source svi
Receiving svi
ip igmp static-group 239.192.X.X
ip igmp static-group *
and on all point to point links (on your l3 devices)
interface gig
The above configuration is valid and functional.
Thank you
Hi panayiotiscy
I've tried your commands but I have not been able to set all.
I have a core 6500 and gives me some commands that does not support them.
Thanks for your support
Aurelio
Hi Aurelio,
One more command that you need to use is the following (in global mode)
This command must be issued on all involved l3 devices
It should work for you.
Aurelio,
What is the multicast Address that you are using
for your test?
Please provide the output of the following CLI commands:
Switch# sh ip mroute "the multicast address"
T.
Hi Tomas:
I found the solution to the problem I had, is a change in the VLC TTL
Check out this link to see the solution: http://forum.videolan.org/viewtopic.php?f=2&t=60983&p=35917
******           THIS IS THE SOLUTION              ******
If there is a shortcut on desktop, open the properties.. It must be like "C:\Program Files\VideoLAN\VLC\vlc.exe" --intf wxwin
after this line, add a "--ttl 10" you must ttl value according to your network diameter..
your shortcut will be
"C:\Program Files\VideoLAN\VLC\vlc.exe" --intf wxwin --ttl 10
this will solve ttl issue on GUI.
Regards and thanks.
1269
