RS232 control of Sharp TV
I am working with DMM 5.2 and DMP4400G w/ 5.2
I am attempting to control a Sharp TV (LC-42D65UT) through DMM system tasks.
The Sharp TV is looking for text control rather than hex apparently.  Command codes are listed in the manual.
The format is 4 command digits followed by 4 parameter digits followed by a carriage return.
For instance, the Power off command is POWR0 followed by 3 spaces(all parameter digits MUST be filled, hence the 3 spaces)followed by a carriage return.
Using Putty I can control the TV from my PC through Putty and the command is executed as soon as I hit Enter(CR).
I ran the system task to control non-DMTech displays, then I created a system task with the following command  rs232.tx_str=POWR0
When I connect the DMP to my PC and send the command formatted without the spaces or CR the DMP sends the text correctly to Putty.  If I include a space anywhere in the command the DMP sends nothing.  The TV does not accept the command without the spaces and CR.
So, is there a way to include a space and CR in a text string to be sent by the DMP and have it send successfully the entire string?
Thanks for any help.  Mike
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: RS232 control of Sharp TV
Sorry but the SharpUSA site is down so I can't get your particular model but here is an example
to accomplish you tasks:
Sharp LC-42D64U
Sharp product manual
http://www.sharpusa.com/files/tel_man_LC45GD6U.pdf
Page - 95 - 97 rs-232 info
Ascii to hex conversion
http://www.laynetworks.com/ASCII%20to%20hex%20value%20chart.htm
Sharp - RS232.Control
To use the RS232 commands on the DMP the serial port must be set to ON and be
pointed at the /dev/ttyS1 device.
To check this create a System Task to check your settings using number 5 below.
If your serial port is anything other than /dev/ttyS1 use number one to set it correctly.
1 Create a system task under application
use type "set"
name it "RS232 ON"
init.startService_rs232=yes&rs232.device=/dev/ttyS1&mib.save=1&mng.reboot=1
2 Create system task "RS232 OFF"
use type "set"
init.startService_rs232=no&rs232.device=/dev/ttyS1&mib.save=1&mng.reboot=1
3. Create system task "TV On" (((ascii =powr1_ _ _ + cr)))
use type "set"
rs232.tx_hex=504F5752312020200D
4. Create system task "TV OFF" (((ascii =powr0_ _ _ +cr)))
use type "set"
rs232.tx_hex=504F5752302020200D
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Sharp LC-42D64U
use type "set"
name it "RS232 ON"
use type "set"
use type "set"
use type "set"
Thank You!
T.
Worked great!!  Thank You!!
Mike
Just a small extra step that some of you might need to take.  On some Sharp displays the remote ON command needs to be enabled.  To do this turn the display on with it connected to the DMP.  Make sure rs232 is enabled on the DMP.  Create and send the following advanced task.
Create system task "TV ON ENABLED" (((ascii =RSPW1_ _ _ +cr)))
use type "set"
rs232.tx_hex=52535057312020200D
This will enable rs232 power on command,
   COOLLLLLLL!!   confirm this is work on sharp.
18283
