Scheduling Playlists / Presentations for Future Play
We have found that when you schedule a playlist or presentation for "Future Play" the DMP does not revert back to the original presentation when the event is finished. Has anyone experienced the same issue or found a work-around?
Re: Scheduling Playlists / Presentations for Future Play
Do you create Playlists / Presentation from DMM, right? It is because of code that generate after you create playlist / Presentation. You must modify code yourself in order to play your playlists one time and back to normal playlist.
Or you need to create another scheduling command DMP to play another playlist.
have the same problem!
there is a playlist scheduled to play for example from 1 am to 5 pm.
When  I schedule a second Playlist to run from 2 pm to 3 pm then after finisched this second playlist I got a black screen on my DMP. there is no fallback to the first scheduled Playlist 1 !
366
