Community Member
Scientific Atlanta D9022, D9032 delay?
Somebody knows what time delay these encoder add to the a live video or VoD (if applicable) streaming?
1 ACCEPTED SOLUTION
Community Member
Re: Scientific Atlanta D9022, D9032 delay?
I have not tried the D9022.  The D9032 is a loaner from Cisco for a POC we're doing.  Sorry.
Community Member
I'm using a D9032 encoder on a live video stream in a lab setting, and the delay is really not that noticeable.  I'm seeing anywhere from a .5s to 1.0s delay.  I'm using a digital receiver as the input, and the delay is low enough that it is still practical to use the remote to change the channels while watching the television multicast on a DMP.
Hope that helps!
Community Member
Sure it does!! Thank you.
Any comments about D9022? Because due to costs I am considering it for a customer.
Community Member
825
