Scientific Atlanta with Cisco Digital Signs
Tiberie Kirijas
Hi Tomas,
Wanted to ask you, if i want to play a DMD presentation with live feed through Digital Signs, would I need Digital Cast license also, or just create a playlist with UDP multicast source when using SA encoder?
I see that in DMD there is this option "Enterprise TV" and all the info that I found for it,that is Digital Cast object. Can you please clarify this?
Do you have any guide for streaming live feed for Digital Signs.
Thanks a lot,
Tiberie
Tomas de Leon
Tiberie,
There are a couple of ways to display live streams on the
digital signs:
* Use CAST and display the channels
  (requires CAST license)
* Use a playlist with UDP asset in the playlist
* Use DMD and add media playlist with UDP asset
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Tomas de Leon
Tiberie,
digital signs:
Thank You!
T.
Tomas, to be clear that I understand the concept and workflow...
One can connect analog camera for live feed to the Scientific Atlanta 9032SD encoder and than get IP converted MPEG2 multicast stream to the DMM - > DMPs and so forth... right!?
Tiberie
Tiberie,
you need to look at the inputs on the 9032D.
I don't know if they have analog inputs,  I don't have
one to see.  Typically, folks have a set top box or
DVD player attached playing content.
But as long as the Video Camera has outputs that
equal inputs on the SA Encoder then it should work.
the workflow is signal input to SA Encoder which then
encodes stream into mpeg2 TS stream and uses multicast
to send into the IP network.
UDP Assets can then be added to the media library of the
DMM or the DMP can display the multicast stream directory.
Video feed -->  sa encoder --> mpeg TS stream via multicast --> DMM or DMP --> attached Display
I hope this helps!
T.
