SNMP on DMS 5.2
Hi all,
Has anyone implemented/enabled the SNMP module on DMS?
  • Digital Media System
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: SNMP on DMS 5.2
"The only issue i'm facing now, is that while i'm receiving syslong,snmp for the DMPS unreachable, i cant receive the email notification.
Is anything wrong with the email notifications on 5.2?"
Please explain further...
The only Alerts for DMPs are DMP Outages, Restarts, IP Conflicts, and Registrations.   Define what you
mean by unreachable?
The Email, Syslog, & SNMP all appear to be working in my 5.2 setup for the alerts listed above.
T.
Re: SNMP on DMS 5.2
Yes, I have the module configured & enabled.
Do you have specific question(s) on configuring?
T.
Re: SNMP on DMS 5.2
Hi Tomas,
Thanks for asking because i do have some guestions(!) :
1) What NMS software are you using?
2) How much effort is needed(in terms of configuration) after "importing" the 2 .my files from Cisco to your NMS in order for the NMS to be able to receive the traps from DMS?
Re: SNMP on DMS 5.2
I use Kiwi Syslog Tools for my testing.
http://www.kiwisyslog.com/
Not much configuration to get this to work.
Just follow the DMM User Guide and the
Kiwi Readme docs.  Very little to config.
T.
Re: SNMP on DMS 5.2
But this is only to receive the syslogs?
What about the snmp?
Re: SNMP on DMS 5.2
I also use it for SNMP.  You can configure it for SNMP.  Download
the free trial and test it out.
Cheers!
T.
Re: SNMP on DMS 5.2
HI Tomas,
I have downloaded the Syslog Server from Kiwi but i cant import the .my files from Cisco.
I can only receive the SNMP traps to the Kiwi but they are "translated" to syslog.
Am i doing something wrong here?
Re: SNMP on DMS 5.2
The Kiwi Syslog application was suggested to use for monitoring DMS Syslog & SNMP alerts not for
a NMS application for all of your Cisco or other devices.  I am sure the Solarwinds and other
vendors have a full compliment of tools and services.
What I use for my DMS setup is the following:
* Kiwi Syslog for DMS SNMP & Syslog ALERT notifications
* iReasoning for DMS MIB Browsing
I am not a NMS Expert and would advice you to seek additional assistance if
you are looking for a "Complete" NMS Tool for ALL of your Network Entities..
Cheers
T.
Re: SNMP on DMS 5.2
Hi Tomas,
Thank you for sharing with me(us) your DMS setup.
Indeed, ireasoning seems to be receiving the DMS traps at once without a lot of configuration in comparison with solarwinds and whatsup!
I'm also using the kiwi and i can receive the syslogs just fine.
Thank you
Re: SNMP on DMS 5.2
T.
978
