Which USB Flash Keys are supported?
panayiotiscy
Level 4
Level 4
I was looking for the USB compatibility matrix in this document: http://www.cisco.com/en/US/docs/video/digital_media_systems/dms_compat.html
and i can see that is not updated ( latest version in the document is 5.1)
Are you aware of any updated version of this document?
In addition, i 'm mostly interested on the usb flash keys i can use in v5.2 . Have you tried any apart from the ones in the compatibility table?
Thanking you
Tomas de Leon
AFAIK, there is not an updated list of USB drives that have been tested with
the 5.2.x releases.   There are so many vendors & models of USB drives that
we can not possibly test them all and validate them.  The List that you mention
in the Matrix URL link is a good reference to follow for 5.2.  If you stay with the
listed manufacturers list & brand names, You "should" be ok, but the only true
test is using it first hand.
I would suggest that you purchase the USB Drive of preference and test a single
DMP-4400 & DMP-4305G to verify successful operation.  Once verified, then you
can purchase additional drives for your desired deployment.
Cheers!
T.
