WOWZA live streamming with SNS to Iphone problem
Dear All
Kindly help us., we implement live streamming from wowza with cisco show and share Iphone.,
WOWZA streamming
     - rtmp://[wowza-ip]:1935/live/mp4:stream.stream
     - http://[wowz-ip]:1935/live/mp4:stream.stream/playlist.m3u48
We place the http://[wowz-ip]:1935/live/mp4:stream.stream/playlist.m3u8 to SNS Video URL live event but it not work when open the page from IE.
There was the popup., "Connection error to server" .,
The streamming " http://[wowz-ip]:1935/live/mp4:stream.stream/playlist.m3u8" is fine when test with VLC.
Please kindly suggest us ., is there any wrong with my configuration.
Vido URL permit only 1 link., if we change to be "rtmp://[wowza-ip]:1935/live/mp4:stream.stream"., the IE able to open it fine but not work for Iphone
Best Regards
Len
For Wowza , please check the below link:-
http://www.wowza.com/forums/content.php?88
For IPHONE:-
Q1-What about HTTP streamin , not live?. Is this working , or you have only TCS integration?.
Q2-Can you please use the following http://wowza IP:1935/vod/h264:  This is as example?. Please use different folder which is used by RTMP traffic ?.
Q3 Did you integrate with Cisco MXE 3500 , please to change Quicktime version ?. Version 7.1 is tested and working perfect with IPHONE/
Thank you
please rate all useful information
It still not work.,  the http stream working on vlc but not for sns application on Apple device
Did you enable Mobile applications on your SNS?.
Step 1
Choose Administration from the global navigation.
Step 2
Choose Manage > Preferences and Settings.
Step 3
To enable this feature, check the checkbox under Mobile Application Access in the Settings area.
Other Question
your configuration for live events .What about if i used IPHONE to see video from your SNS , is streaming work ok on your iphone?.I need to know if the problem in live events only or on mobile applications.
Thank you
Please rate all useful information
668
