04-17-2014 09:43 AM
Hi. Is there any way to call a variable in a regular expression, instead of explicitly defining it? For example,
THIS WORKS:
action 10 cli command "show run | section router ospf"
action 20 regexp "passive-interface Serial4/0" "$_cli_result"
BUT THIS DOES NOT:
event manager environment _circuit1 Serial4/0
action 20 regexp "passive-interface $_circuit1" "$_cli_result"
Solved! Go to Solution.
04-18-2014 07:38 AM
Unfortunately, not all fields in an applet are set for variable expansion. This is one of them. You can convert this applet to Tcl using our tool at http://www.marcuscom.com/convert_applet/ . Or you could do:
action 20 regexp "passive interface ([A-Za-z0-9/\.:]+)" $_cli_result match intf
action 30 if $intf eq $_circuit1
04-18-2014 07:38 AM
04-18-2014 08:05 AM
WOW, thanks Joseph! That regexp worked like a champ.
Sooo glad you monitor and respond to these discussions.
04-18-2014 08:37 AM
Ok, I have a follow-up. How can I modify this script to catch more than one passive-interface. I have this:
action 20 regexp "passive-interface ([A-Za-z0-9/\.:]+)" "$_cli_result" match _intf
action 30 if $_intf eq $_circuit1
action 40 elseif $_intf eq $_circuit2
...but it'll stop at action 30 if _circuit1 is found. I have to run the script again to catch _circuit2. How can I run the script once to catch both circuits?
04-18-2014 09:59 AM
event manager environment circuits Serial4/0 Serial3/0 Serial2/0
action 20 foreach circuit $circuits
action 30 if $intf eq $circuit
04-21-2014 07:37 AM
Ok, not sure what I'm missing, but the script will only catch the 1st interface listed as passive, but not the 2nd.
event manager environment _passive Serial0/0/0 Serial0/1/0
event manager applet UNPASSIVE
event none
action 25 foreach circuit "$_passive"
action 30 if $_intf eq $circuit
action 40 puts "$_intf"
action 50 end
action 99 end
04-21-2014 07:41 AM
If the config contains more than one passive interface, you need to move the foreach loop higher:
action 20 foreach line $_cli_result "\n"
action 30 regexp "passive-interface ([A-Za-z0-9/\.:]+)" $line match intf
action 40 foreach circuit $passive
action 50 if $intf eq $circuit
action 60 puts $intf
action 70 end
action 80 end
action 90 end
04-21-2014 12:06 PM
Thanks, Joe! I was finally able to get it working perfectly thanks to your help. For clarity, here's what I ended up with:
event manager environment passive Serial0/0/0 Serial0/1/0
event none
action 20 foreach line "$_cli_result" "\n"
action 30 set intf "none"
action 40 regexp "passive-interface ([A-Za-z0-9/\.:]+)" "$line" match intf
action 50 foreach circuit "$passive"
action 60 if $circuit eq $intf
action 70 puts "$intf"
action 97 end
action 98 end
action 99 end
04-24-2014 07:22 PM
Strange things going on. The above script worked perfectly in the lab. I changed the event to a CRON job, and it worked fine. I added the same script to a production device...and the history shows it invoking the script, but nothing happens.
LAB - 15.1(4)M7
PROD - 12.4(24)T3
Surely this has got to be a bug, right? I even tweaked it to run every minute and added a bunch of 'puts' so I could see how far the script was going:
event timer cron cron-entry "0-59 * * * *"
action 05 puts "STARTING!!!"
action 11 puts "11"
action 21 puts "21"
action 31 puts "31"
action 41 puts "41"
action 50 if $intf eq $circuit1
action 50.1 syslog msg "CRON job making $intf unpassive"
action 50.2 cli command "enable"
action 50.3 cli command "config t"
action 50.4 cli command "router ospf 77"
action 50.5 cli command "no passive-interface $intf"
action 50.6 cli command "end"
action 51 puts "51"
action 98 end
action 99 end
Still, nothing. I then changed the event to 'none', and invoked it manually, and I got this result:
STARTING!!!
11
21
31
41
21
31
41
21
31
41
21
31
41
It looks like it only read the first 4 lines of the OSPF config before stopping, when in reality my 'passive-interface' commands are further down than that.
1) Why did this script only work manually and not with CRON?
2) How do I get this script to run ALL lines of the OSPF section, and not just the first 4?
04-25-2014 08:52 AM
The timing of these messages would be more revealing than the messages themselves. Perhaps your applet is taking too much time on the production router. Try increasing maxrun to 60 and see if that helps.
04-29-2014 06:31 AM
Tried increasing maxrun...no affect. I also tried a much simpler version of the script:
action 11 puts 11
action 21 puts 21
action 30 if $_regexp_result eq 1
action 30.1 syslog msg "CRON job making $circuit1 unpassive"
action 30.2 cli command "enable"
action 30.3 cli command "config t"
action 30.4 cli command "router ospf 77"
action 30.5 cli command "no passive-interface $circuit1"
action 30.6 cli command "end"
action 31 puts 31
action 40 end
And here's the OSPF config:
router ospf 77
router-id xxxxxxxxxxxxxxxxx
log-adjacency-changes
auto-cost reference-bandwidth 20000
timers throttle spf 10 100 5000
network xxxxxxxxxxxxxxxxx area 1
network yyyyyyyyyyyyyyy area 0
And this is as far as it gets when ran:
000879: Apr 28 20:26:00.016 CDT: %HA_EM-6-LOG: UNPASSIVE: 11
000880: Apr 28 20:26:00.016 CDT: %HA_EM-6-LOG: UNPASSIVE: 21
I am now convinced it's an IOS issue, as it works in my lab (15 code), but not in prod (12 code). But it really stinks for me, as I still need a solution to make these interfaces unpassive. Any ideas are appreciated.
04-29-2014 07:26 AM
In action 21, puts the contents of $_cli_result to make sure you're getting what you expect. Perhaps you have AAA command authorization, and you're getting back "Command not authorized" or something.
04-30-2014 07:47 PM
Ok, Joseph, you're on to something. I am not getting the desired $_cli_result. I experimented with 2 very simple scripts:
event none
action 10 cli command "enable"
action 20 cli command "show running-config"
action 30 puts "$_cli_result"
and it works. Then I tried adding the CRON event:
event event timer cron cron-entry "0-59 * * * *"
And nothing. I even tried adding a user called, 'EEM':
username EEM priv 15
event manager session cli username "EEM"
Still nothing. Why would this work with a manual event, but not a CRON event?
04-30-2014 08:18 PM
So what do you get back from running the command? What does the running config look like?
05-01-2014 06:01 AM
When I run the script manually, I get the running-config 'put' on the screen.
When I run the script via CRON, nothing happens.
It's got to be 'privilege' related, because when I change the script's command to 'show ip int brief'...it works manually AND with CRON. Like I said, I even created the user, 'EEM' with full privileges and it still doesn't work. Here's the config:
username EEM privilege 15
