cisco 1800 failover
domoticity
Hy Everybody.
I have a Cisco router 1800 and i would like use FailOver.
I have my Configuration whch works but i still have a little detail to solve.
hostname routeur-cisco1811
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 XXXXXXX/
aaa new-model
aaa authentication login default local
aaa session-id common
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 192.168.3.2 192.168.3.99
ip dhcp excluded-address 192.168.3.200 192.168.3.252
ip dhcp excluded-address 192.168.3.254
ip dhcp excluded-address 192.168.3.253
ip dhcp pool CASA_LAN
   network 192.168.3.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.3.254
ip cef
no ip domain lookup
ip domain name domoticity.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
username domoticity privilege 15 secret 5 XXXXXXX
archive
 log config
  hidekeys
ip ssh time-out 60
ip ssh logging events
ip ssh version 2
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 3 list boolean and
 object 1
 object 2
interface FastEthernet0
 description Acces principal FTTH
 ip address 192.168.1.254 255.255.255.0
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet1
 description Acces secour 3/4G
 ip address 10.0.0.254 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet2
 switchport access vlan 2
interface FastEthernet3
 switchport access vlan 3
interface FastEthernet4
 switchport access vlan 4
interface FastEthernet5
 switchport access vlan 5
interface FastEthernet6
 switchport access vlan 6
interface FastEthernet7
 switchport access vlan 7
interface FastEthernet8
 switchport access vlan 8
interface FastEthernet9
 switchport access vlan 9
interface Vlan1
 no ip address
interface Vlan2
 description domoticity
 ip address 192.168.2.254 255.255.255.0
 ip nat inside
interface Vlan3
 description casa
 ip address 192.168.3.254 255.255.255.0
 ip nat inside
interface Vlan4
 description stockage
 ip address 192.168.4.254 255.255.255.0
 ip nat inside
interface Vlan5
 description domotique et cameras
 ip address 192.168.5.254 255.255.255.0
 ip nat inside
interface Vlan6
 description sentinelle
 ip address 192.168.6.254 255.255.255.0
 ip nat inside
interface Vlan7
 description Monotoring surveillance generale
 ip address 10.1.1.254 255.255.255.0
 ip nat inside
interface Vlan8
 description Orange travail
 ip address 192.168.8.254 255.255.255.0
 ip nat inside
interface Vlan9
 description Serveurs multimedia
 ip address 192.168.9.254 255.255.255.0
 ip nat inside
interface Async1
 no ip address
 encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 3
ip route 0.0.0.0 0.0.0.0 10.0.0.1 10
ip route 90.116.11.243 255.255.255.255 192.168.1.1
no ip http server
no ip http secure-server
ip nat inside source route-map BACKUP_ISP interface FastEthernet1 overload
ip nat inside source route-map MAIN_ISP interface FastEthernet0 overload
ip sla 1
 icmp-echo 192.168.1.1 source-ip 192.168.1.254
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 90.116.11.243 source-ip 192.168.1.254
ip sla schedule 2 life forever start-time now
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 100 permit ip 192.168.3.0 0.0.0.255 any
access-list 100 permit ip 192.168.4.0 0.0.0.255 any
access-list 100 permit ip 192.168.5.0 0.0.0.255 any
access-list 100 permit ip 192.168.6.0 0.0.0.255 any
access-list 100 permit ip 192.168.8.0 0.0.0.255 any
access-list 100 permit ip 192.168.9.0 0.0.0.255 any
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
route-map BACKUP_ISP permit 10
 match ip address 100
 match interface FastEthernet1
route-map MAIN_ISP permit 10
 match interface FastEthernet0
control-plane
line con 0
line 1
 modem InOut
 stopbits 1
 speed 115200
 flowcontrol hardware
line aux 0
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
event manager applet CLEAR_NAT_DOWN
 event track 3 state down
 action 1.0 cli command "enable"
 action 2.0 cli command "clear ip nat translations forced"
event manager applet CLEAR_NAT_UP
 event track 3 state up
end
So i have a Fiber Box where is connected the wan1 (FastEthernet0) and a 3gBox where is connected the wan2 (FastEthernet1).
When disconnect the wan 1,it balances to wan2. And when i connect again the wan 1,it balances to wan1.
In my configuration, in red you have my ISP ip.
My provider changes my ISP ip sometimes and every internet Cut.
I have a FQDNs at noip.
a very nice person from the forum :), tells me that i can't remplace my ISP ip by my FQDNS and it's better to turn to a EEEM script.
I know only do bash and php script.But no EEEm Scripts.
Some can help me please :)
36 Replies 36
You need to post the debug output when you execute the policy using the track event detector.  The debug output will appear on any monitored line.
Si When i dit thé débug i have thé line « My ip XXXXX » where Xxxxx is my ip
Hy,
I need you again :)
so when i put
event none
instead
event track 2 state down
and launch the script manually it works.
I don't understand what is wrong
I have been asking you for the debug output, but you do not provide it.  Without that I cannot say why the script does not work when you use the track event detector.
Sorry.
I dont know how toi use thé débug output.
I Musy include it in the script ?
Thanks a lot for jour help
Enable "debug event manager action cli" and trigger the policy via the tracked object.  Post the output from either a monitored line or the "show logg".
Hy,
Cisco is Magic lol
I haven't modified my script and now everything works.
When i unplug the wan0 or cut the fiber connexion,
it balances into 3g connexion.
When i plug again the wan0 or reload the fiber connexion,
my Cisco router come back to the fiber connexion.
Thank you a lot. :)
